thats another good idea. I just got an oil cable and throttle block. On its way. Another question though, for some reason it seems to run EXTREMELY lean to the point where it barely wants to run. My exact setup is as follows:
psi pipe and direct oil injection
vmax carbs:
55 pilot (2.5 turns out to allow plenty of gas because its a fuel adjuster in the front of the carbs)
157.5 main jet
9EL2 Needles in the bottom clip with the little spacer underneath the clip (most gas flow)
sx nozzles (think they're like P-6? something like that)
1.5 for the needle and seat (which are good)
3.0 slide cutaway
fuel pump is well because it ran wonderfully before the carb switch out and I blew up my last sled trying to get these dailed in
Reason I can tell it's lean? at idle, it has very low rpms but I can flip the choke and the rpms jump a few thousand and the fact that any time I try to hit the throttle it falls flat on its face. Another way is that the sound of the engine sounds lean (like when you turn the fuel off and let it run itself out of gas). ETGs also run hot and spark plugs are white from the very little running it did. I know there are plenty of smart guys out there and it clearly seems I'm not one of them. lol
