On the clutch side I can wiggle it around alittle, should this be changed or is this normal? Bearing doesnt move but the shaft moves in the bearing collar. Can this be removed by taking the air box out? is it pressed on or set screws also?
Figured it out, its a collar bearing and the set screws where loose..
bADa$$ SRX
Buddy had a viper same thing happen, the bracket holding the bearing came loose. He didn't notice till it wore so much that the secondary was rubbing against the primary.....
super1c
Super Moderator
make sure you clean those screws up good and use at least red lock tight! Common problem that can do a lot of damage if left unchecked
