02 Viper upper jack shaft
yamahinn03
OSHKOSH WI.
On the clutch side I can wiggle it around alittle, should this be changed or is this normal? Bearing doesnt move but the shaft moves in the bearing collar. Can this be removed by taking the air box out? is it pressed on or set screws also?
Buddy had a viper same thing happen, the bracket holding the bearing came loose. He didn't notice till it wore so much that the secondary was rubbing against the primary.....
