Robs96max4
Does anyone know what the steps are to remove a jackshaft from a 2001 srx? It's the shaft that the secondary is on. Thanks
I have a 98 that has excessive rotational rotor play, if its just the key whats the best procedure to remove and replace the key stock?
So what is the the best method to inspect the rotor hub to verify its the failure prior to tear down? Can I remove the top drive sprocket and loosen the secondary jack shaft bearing lock and slide the shaft to the secondary side to expose the key and key way on the rotor hub? And if the rotor has to be replaced if I understand correctly the best way is to remove the entire chain case assembly?
