Hey everyone...new here, and I have a few questions about my new to me sled. I may have made a bit of an impulse buy, and now in over my head. I purchased a 98 or 99 Mountain Max 700. I have conflicting paperwork. I bought off a fellow who said it was a 98. The paperwork I got that tranfered ownership to him from previous owner indicates it's a 99. Are the two sleds the same? What other motors are the same? SXR or SRX? Viper? I have done lots of reading on here, and it seems they changed in 2000?
I am having a plug fouling issue. Done lots of reading and found lots of good advice. First thing I have to do is clean the carbs. I've already replaced the caps with NGK LB05EP. I took off TB05EM. I checked the old ones and were at 4.80 K ohms, 4.85, and 5.00. Are those two within spec? I fouled plugs tonight after changing caps. Aaargh! I
am letting the sled warm up before touching the throttle. It will run for about 5 mins and die, but it resarts just fine. Cold compression check was also good. within 5psi on all three. This sled is not stock, but has many miles on it, so I'm sure it ran fine at some point. The previous owner claims the sled ran awesome for him. Might be bs, I don't know. He rode it for a year and a half. Engine was rebuilt just before he got it, and he didn't put many miles on it I don't think. He got it from a frind of his, and claims the motor is stock. The sled has Decker pipes on it. Sounds awesome! Most of my riding will be at aroud 2000ft. Does anyone have jetting recomentations? It is a 151 with an Ekholm tunnel, dropped and rolled, Boysen reeds. New primary. About an 8 inch bar riser. This sled should haul butt, if I can get itnto run right. Seems to me, it has all the right mods done to it. But, a few things are in rough shape. There is no speedo as the cable won't clear the secondary. That is another post and I am working on that. The right grip and thumb warmer have only worked once. Left grip never has worked. The temp sensor has a broken wire on the harness side. I think I can fix that. Should the oil light come on when it is started? My sons Exciter does, but mine doesn't. The TORS is bypassed, and I can't find the other side of the harness to reattach. The cable seems tight now, so thats probably why. Need to check the oiler cable too. I want to play with the clutching too. I would like to get it a bit more trail friendly. Right now, it seems to like being wot, not midrange. Is that partly the reeds?
So....am I in over my head? I am capable of wrenching on this stuff, just not too knowledgeable.
Sorry for the long post and the many questions.....
