Exciter 2 sx engine into st exciter
barkerman77
Madoc, Ontario, Canada
So I bought a st a few months ago with no motor in it. Everything is there minus the crank cases and cylinders and stuff. I am gonna take my sx motor and shove it in. I want long track and electric start. Has anybody installed electric start on an sx before? Do I need to change the magneto or anything?
You will have to change the flywheel. Get one from a 91-93 Exciter with electric start. For some reason I think you will have to change the wiring harness as I believe the stator connection and cdi connectors are different from a std Exciter II.
94-96 vmax 600 will pretty much drop right in. I think you will have to change one of the front motor mounts, but I cant recall. Just make sure you use the carbs and clutching from the 600. The wiring would be the most difficult thing I believe. Not that its hard, just titious.
Its been done and can be done. I had an 88 exciter with a vmax 600 engine in that I bought last year for parts. If you have an entire donor sled I would go for it.
