TPS Guru's
00SRXWHERRY
Clarkston, MI
Ok I was having a hell of a time getting my TPS adjusted today. I have made the homemade 5 volt TPS tester from the tech pages. the tester holds a steay 5.01 volts. So it's in working order. Now when I hook it up to the tps, the math tells me I should be at .681 volts D/C just sitting there. It's all fine and dandy it just seems to be extremy touchy. Every time I make an adjustment it takes 10 to 20 seconds for it to settle down and hold a steady voltage. Trying to get the .681 volts just seems impossible. Is this the way it is or is something wrong with my TPS?
It sounds to me like you have a defective TPS. The voltage changes should directly correspond to the rotation of the sensor. The readings should not vary once the sensor position is stationary. The sensor works just like a light rheostat in your house.
On my 2002 SRX, I had a TPS that was varying the voltage throughout its rotation and it gave me all kinds of grief until I replaced it.
Ok just did a resistance test like the book says. Between the positive and neg terminal on the TPS it is suppose to between 4-6. I'm getting 6.14.
got it out. thanks guys. hopefully i'm not replacing it for nothing it 200 bucks.
Before you buy a new one try to borrow someone elses or at least use you test methods on another TPS to ensure your testing is not flawed.
Also try measuring the resistance as you rotate the TPS to see if it jumps all over the place as well.
Sideshowbob, I would love to test it against another tps, I don't know anyone with a SRX in my area also when I run into someone with one it pretty rare on the trails. When I try to rotate it it does just jump all over the place it's verry verry touchy. I may shoot some video to post how touchy it is.
Dang already ordered it from my local dealer. I will have it in 3 to 5 businesses days. They charged 201. Don't know if it is the updated part.
well hopefully you will know once you install the new one the difference because it sure cured my issue.Sled is running like it should since that time..Good luck and keep us informed also.
Gota say holly shit. I haven't gotten to even ride the machine yet but just can tell the difference in the garage after putting the new TPS in. Idle is much smoother rpm is just snappy almost scarry and wide open just seems retarded compared to old TPS. As far as testing the old to the new it's 2 different worlds as far as voltage readings. I have a feeling this is going to be a whole new machine compared what i'm use to. Just worried all the clutch and jet tuning I have been doing is just having to be started over with the new TPS. CHECK YOUR TPS!!!!!!!!!
