00SRXWHERRY
Ok I was having a hell of a time getting my TPS adjusted today. I have made the homemade 5 volt TPS tester from the tech pages. the tester holds a steay 5.01 volts. So it's in working order. Now when I hook it up to the tps, the math tells me I should be at .681 volts D/C just sitting there. It's all fine and dandy it just seems to be extremy touchy. Every time I make an adjustment it takes 10 to 20 seconds for it to settle down and hold a steady voltage. Trying to get the .681 volts just seems impossible. Is this the way it is or is something wrong with my TPS?
