moose54451
Hi i posted last season about having some rpm issues with my 01sxr 700 never did get it resolved last year so here i go again...pretty much what happens is from a dead stop if u floor it it will only hit about 7800 rpm..if u floor it and let off at about 40 mph and hit it again she will jump up and hit about 8500 rpm which i believe it should be hitting all the time..also on my last ride last year my yamaha belt lost all the fins on the back side of the belt...note the belt only had about 200 miles on it... I took the secondary off this year and cleaned it noticed it had a little play in the bushings which my local yamaha dealer mechanic said that should be fine??? Not sure what it is...primary looks good?? Why would my belt tear up? Could this be causing my rpm issue?? Any input would be greatly appreciated thanx!
