01 viper crank and rods in 01 srx?
01 SRX
Central Michigan
Hi guys. At the end of last season I blew a rod bearing on my center cylinder. I found a good lower end for the same year viper with a good crank cheap. I'm wondering if I can put my top end from my srx on the lower end of the viper engine? I know the pistons are different but I'm not sure about the crank or rods. Any help would be greatly appreciated.
theres no differance in the pistons other then some coating and piston weight so it will all interchange as far as bottomend goes, any year viper 02-05 will interchange with 2000-02 srx.
Thanks. I thought the cylinder diameter and part numbers were different from the srx? The srx is 695mm and I thought that the viper was like 697 or 698mm.
