01 SRX
Hi guys. At the end of last season I blew a rod bearing on my center cylinder. I found a good lower end for the same year viper with a good crank cheap. I'm wondering if I can put my top end from my srx on the lower end of the viper engine? I know the pistons are different but I'm not sure about the crank or rods. Any help would be greatly appreciated.
Devilin AblueDress!
Did they make a Viper in 01? Thought 02 was first year. Not 100% sure but I think you can/should run the viper crank in the SRX cases.
theres no differance in the pistons other then some coating and piston weight so it will all interchange as far as bottomend goes, any year viper 02-05 will interchange with 2000-02 srx.
01 SRX
Thanks. I'm not sure what year they started with the viper for sure either. It was posted as a 01 MM viper bottom end.
01 SRX
Thanks. I thought the cylinder diameter and part numbers were different from the srx? The srx is 695mm and I thought that the viper was like 697 or 698mm.theres no differance in the pistons other then some coating and piston weight so it will all interchange as far as bottomend goes, any year viper 02-05 will interchange with 2000-02 srx.
Devilin AblueDress!
Definitely need to verify what it is. 01 Mountain Max is a red head triple......would do you no good.
01 SRX
Ok thank you.
