First ride attempt - snow drifts on my road caused buckled trailiing arm
I bought a used one off of slicks motor sports for my read head sled and it was 60$ and no scratches or nothing.
Update, well a track stud took out the front mounted heat exchanger. So its back in for repair after <20 km. I knew they could be trouble and were on the sled track when I got this. No regretting I never pulled them all out. They are pretty much useless anyway form trail riding. Never help with traction on these tracks.
NOTE: If you have a front mounted heat exchanger remove your studs if you have them. Its only a matter of time before this happens. Good thing I spotted a leak started in shot test runs and when we ran it at the shop it punch a big hole in the exchanger and came off on the ground at the mechanics. There are some design concepts that don't make sense and a from heat exchanger is one of them.
I can't catch a break with this. Engine rebuild and now heat exchanger....after the trailing arm bent. Trying to reverse out a number of times likely broke a stud free.
