J
jaydougempire
Guest
This is an xcr pump for Polaris triples. The guy who gave it to me was running it in the sxr and running premix in the gas tank.
As SSB said, that is not the same pump as used on Yamaha's triples. You can use that style pump if you change your oiling system to direct injection, IE. run 3 individual oil lines to each intake (or carb) and supply the oil in that manner. That is the setup I'm currently using on one of my SRX's.
J
jaydougempire
Guest
Well I'm making up new swear words. Bought a yamaha pump, installed it...got good flow of fuel. Pumping well. Sled still won't start. Pulled over about 10-15 times and no go. Plugs are a little wet with gas...not sure what's going on but I'm losing faith here.
J
jaydougempire
Guest
Nevermind! Got it running. Just had to squirt some more premix in the carbs to get er to fire and she's putting like a kitten first pull.
