YamahaSXR700
hey guys my srx has the DCS and it keeps flashing on WOT and the engiune is perfectly in good running condition its been rebuilt
go buy premium 93 octane and put in it,then if it still does it go buy octane booster or add a gallon of race gas to the tank and dump in, light wont bother you anymore! Your octane is too low. Todays gas is junk.
go up to 2001 srx jet spec. don,t bypass it unless its a race sled. 3:16x (yammie tony)
Hopefully you cut it with some 91. nobody goes full retard unless you have a high compression setup. Otherwise your pistons will become rockets launching through your hood.. Id start with a 50/50 blend to start then tweak it from there. Race gas is like cocaine the more pure it is the more likely your heart (engine) is going to explode on contact
I know its an old post but what octane in race fuel would one use.
no, race gas is the opposite of that, it resist burning, higher octane slows the burning where as for example 87 octane is more volatile. The lower the octane the more powerfull the explosion is. Race gas has higher octane to resist detonation. With lower octane you can make more power however you can not sustain detonation from happening, that's why you cant have a race engine on 87 octane... at least,, for very long!.
I had a buddy of mine put straight "blue" race gas we buy from the res, into a honda 250r stock 3wheeler and it ate itself within about 3 minutes at which point it started ejecting pieces from the inside of the engine to the outside of the engine and this was a fresh rebuild with about 250 miles on it. loved the way the fumes smelled as it was self destructing.
