YamahaSXR700
YamahaSXR700
i absolutely never seen this in my life this is my worst
I have seen it . It does happen.
Just checked ebay, nothing.
WOW that is insane...
A couple of bucks
Those pictures should be under the definition of ... Catastrophic.
dieselcamper01
I had a similar failure last year on mine. The connecting rod on the mag side broke in half. I am still gathering all the parts I need.
roudyroy1
Wow....
devinzz1
One hell of a malfunction! How did the top end fair? Shouldnt be to hard to find a complete bottom end and use whats usable.
Mac
Most likely the cylinder just above the damage has broken off the exhaust skirt. Then the next rotation of the crank pushes the skirt through the block. Have you pulled the cylinder to inspect?
YamahaSXR700
It's retarded I have never seen this happend and no I haven't inspected nothing just took it out the chasaid last night even the Reed valve got a bad beating broke in half it's basicly the cylinder and the mag that keeps it all together. I will inspect sometime today and post more pictires
J
jaydougempire
Guest
Holy shit!!
