02 srx 700 down!!!! Help
YamahaSXR700
River Valley
Guys went for a quick rip today not even for 15 min, sled was running good, i stepped on it and this happend i never seen this before the connecting rod bearing is fine theres is no play in it, found the connecting rod peice in the belly pan, the motor got split basicly in half. heres the pics
10915284_10153051999759626_3949533256092752890_n.jpg1395234_10153051999704626_5282329032406413152_n.jpg10922467_10153051999839626_191854255883908794_n.jpg10942789_10153051983989626_1649760059_n.jpg
One hell of a malfunction! How did the top end fair? Shouldnt be to hard to find a complete bottom end and use whats usable.
Most likely the cylinder just above the damage has broken off the exhaust skirt. Then the next rotation of the crank pushes the skirt through the block. Have you pulled the cylinder to inspect?
It's retarded I have never seen this happend and no I haven't inspected nothing just took it out the chasaid last night even the Reed valve got a bad beating broke in half it's basicly the cylinder and the mag that keeps it all together. I will inspect sometime today and post more pictires
