TJWells
I'm looking for some insight. I have a 2000 srx 700. I recently installed a bender cold air kit.
I jetted up main accordingly 157.5 155 155 pto to stator. As soon as I started it in my heated
Garage I knew something was off. I needed 2nd stage of choke to start and when the chokes
Off it slowly leans out to run on 1 or 2 cylinders. When I snap the throttle even when warm it
At low rpm it bogs unless its on first stage of choke. If the rpms. Are up around 3500 its fine
But off idle I have to nurse it. I've turned out screws from 1.5 to 1.75 and 2 1/8. This helps but
Its not enough. Do I raise the needles or change the pilot jets? Or just pull out what little hair I
Have left.
Have left.
