ryeguy2006a
Hi guys,
I will start off with a little background. This is my first snowmobile, 1998 Yamaha XTC Deluxe 700 just over 3000 miles, and was really excited to start this season off right. Last Friday we got just enough snow to ride, and I have been chomping at the bit to get out. So, after a few short trial runs over the past few weeks in my yard and looking the sled all over(to the best of my knowledge), I headed out on the trails. After riding a few miles, I was very impressed with the sled overall. It has tons of power down low, really great top end, and great handling despite the limited amount of snow ~6". The only issue, if it is one at all, is that every once and a while it would "stick in gear" and when I let off the throttle the sled wants to keep going. As soon as I hit the brake I would hear the clutch click and it would come to a stop. I am assuming it is a sticky clutch or something. Anyway to get to the real problem, I ended up meeting at my uncle's house and I stopped inside his shop to get warm. I was checking over the sled, when we both noticed that the cylinder head looked distorted on the outer cylinders?? When we got to looking at everything, my coolant was low and appeared to be just slightly leaking out the belly pan near the water pump or front cooler.
I haven't touched it since last weekend, but am going to look at it tonight and see exactly what is going on. I was hoping to get a little advice after searching this site extensively. I am going to start with assessing the water pump and trying to see exactly where it is leaking from. I have read many bad things about the brass gear of death, as well as a mechanical bearing. I am hoping that it is something simple like a cracked hose, but from the sounds of everyone's posts doesn't seem likely.
Also, might be worth mentioning that the sled runs excellent, which is what surprised me. Also, no lights came on for temperature. All three cylinders were ~120 psi.
If it does happen to be the brass gear, how do I tell if it the motor is getting oil? Can I just bypass the oil pump by pre-mixing and possibly getting an electric inline water pump? On a very tight budget with a baby on the way, so a major overhaul is out of the question.
Plan for tonight:
Thanks,
Ryan
Plan for tonight:
- Pressure test system
- pull water pump cover
- Assess any damage
Thanks,
Ryan
