Ah I see, so the Comet clutches are an improved design over what Yamaha offered for the SS440 in 83, better performance? What Comet clutch will work with an SS440?
Also, what Yamaha model clutches will interchange with my sled? I'm searching for replacement parts/clutch assy. Right now, I think I'm going to clean it all out at the parts washer at work and take stock on anything that needs to be replaced. Overall, I think it's in pretty good shape, but the missing cotter pin has me worried, there was some damage to the side spider where the washer/pin went. Also, my manual says that there should be no grease inside the clutch except for the sliders. What grease is recommended? I only have the Yamaha blue marine grease. Do I remove the slider and pack the area behind it with grease?
What about the weight pins? Are those pressed out to allow greasing of the clutch weights?
Also, how interchangeable are the clutch components? I have a junk clutch that I was going to rob parts off of, but I wasn't sure if the spider and sheaves were balanced as a set or not?
