Vmax 600sx
Toddwick
CT
Hey, new member here looking for some info on a sled I just picked up tonight. The guy said the chain broke(hoping its nothing more).The guy I got it from said it was Nathan Titus's factory practice sled and was given to Doug Henry(who he got it from). It has full Ohlin's shocks. Trying to look into parts, any idea of what year it is? Thanks
More pics
More pics...
I got the chain case pulled off, I'm guessing the lower bearing gave out which caused the chain to break?
The factory racers were all blue, no matter the year. Judging from the black bellypan, that is a 97 or 98, probably 98.
portyamaha.com is known for good customer service and they are also a site sponsor.
If your sled was indeed a practice sled for the Yamaha team snocross racers, it makes some sense to start with an XTC instead of an SX, even though the SX was the "production racer". The long travel suspension is better for snocross, and the parts are already on the XTC to start with (shocks, radius & steering rods, trailing arms, limiter straps...), then they changed the shocks to Ohlins, likely all 4 of them.
Since blue was the team color, repaint the tunnel (yours does look repainted), radius rods, trailing arms, and hood for 1998, or replace the hood with the factory blue SX version in 1999. The blue seat could be from an SRX for 1998, or SX/SRX in 1999. A couple other items that point to 1998, or 1997, are the rear suspension wheels (aluminum with rubber tire), and the black rear bumper cover.
You could also try to find the serial number on the engine and compare with the tunnel VIN. I'm not exactly sure where it's located but I believe it is stamped into the aluminum casting area that houses the flywheel/stator.
Just keep in mind, the sled has been around for awhile and many things could have been changed over the years. It could be a look-alike racer that someone put together back then, or it could be as it was when Henry, or Titus, had it.
I think it is legit. The VIN number plate is not like on Production sleds, and yes it is an XTC, I have the race book from 1998 that shows partially how to make one.
