TORS/kill switch/wire rub?
Hi j5ferry1. I sent one message but I don't think it saved, so trying again. The throttle block has a connector with three wires in it. The black is ground. The connector on the other side has a chocolate or brown line which matches up to the black ground. This chocolate line was broken off about 5" in. You have to peal back tape and it is in a hard spot to get to. I had to take off the bars and pulled on the plastic while a friend soldered the lines. Pain in the butt.
Thanks, I will check it out next weekend! Sweet that you figured yours out.
