Clutching for porting
badazzyammie
browncity
Ok so I was gunna run green secondary yellow silver yellow primary 4.5 in both holes and a 41/53 helix is this a good set up even with porting done and possibly bigger pistons
no, that wouldnt be good for a ported engine with more power let alone a big bore. Thats for a stock 98-99 srx700.
what year srx are we even talking about?
who is doing the work on the engine? amount of work done/power output will determine where your engine rpm will be, ask your builder......
why would you use stock srx weights in a modded engine??, kinda defeating the purpose.... you should use something to clamp the belt to take advantage of the new power.
Mrviper didnt say it but i will. 8bu or Heel clickers;)! Lots of reading and tuning will get you where you want to be
Sorry if took me so long to reply mr viper it is a 02 Srx the guy said it will give about 15 hp but I think I'm going to get the heads done too I think I'm also gunna stick with std Pistons depends motor only has about 2500 on it and I'm not saying I will use the stick weights never had a ported sled so I was just wondering if that set up would work or not any info on a good set up would be great
