1999 600 srx stock
120 1" picks
Going to radar run tomorrow
Here is my starting setup
8bu-10 3.1 tip 0.8 inside
www primary
silver secondary@70
47/41 cam
23/35 gears 1.52
geared for 105
update tomorrow night
RJ21
120 1" picks
www primary
silver secondary@70
47/41 cam
23/35 gears 1.52
geared for 105
RJ21
bADa$$ SRX
Goodluck, I can usually run high 80s in 660' with my set up. Never ran 1000'.
fastsrx
Good luck, That's sounds like a pretty tall gear for a 600. I hope it works. Keep us posted. I see on your other post that you ran 98 mph, that's pretty good. if your sled is stock
Little heavy with a silver spring?
Yes the sled is stock. the 98 mph I ran was a different setup and 23/39 gears Tomorrows race is 40.00 to run all day so I am gonna use it as a test and tune day I can always go back to my 98mph setup I write every combination down to remember what worked and why otherwise I would forget what I tried
YAMMIEGOD3:16
i like your setup. get those weights right, they fly. 3:16 (yammie tony)
Ran today. not good no matter what i did it wouldnt go over 8260rpm went back to 23/39 gears pulled hard 200ft at 8260 then dropped down to 7800 then slowly climbed to 8100 and was the best it ran all day got first place at 97.9mph but still upset with sled
fastsrx
Congrats on first place. Your close on your clutching. Just have to keep testing. Probably would have run 100 mph or better if clutching was spot on.
The weird part is no matter what gram weight i used the rpm didnt change
fastsrx
Did you try different weight or take weight off the 8bu"s
Took weight off the 8bu-10s. 2 grams off tip rivit rpms didnt change went back to 89A weights rpms went up to8280 tonight i took rivits out of 8bu-10 tip gonna try it tomorrow
Took 2 grams off 8bu-10s no change in rpm went to 89a weights ran better rpms went to 8280 tonight i took rivits out of tip of 8bu-10s gonna try it tomorrow at another radar run in spicer mn.
Took 2grams off tip off 8bu-10s no change in rpms Went to 89a weights rpms went to 8280rpms took tip rivits out of 8bu-10s tonight gonna try them tomorrow at radar run in spicer mn
staggs65
I've had better luck using shallower finish angles with bu10s. 37 finish with a green spring has worked best for me. That's been on 700s though
YAMMIEGOD3:16
i liked your setup, this is a 600 srx thats peak is 8350. i agree with jeff, i tested the 8bu-10 more than any weight out there stay with them. try a helix with lower finish. 3;16 (yammie tony)
Todays results tried every combination of helixs and springs and degree wraps we could while using the8bu-10 weights, we tried diferent 89a weights with all combos, nothing we did would get our target rpm (8500)( 99 600), then we went the other way and tried 89a weights at 56 grams, gwg spring, 48/38 secondary with pink spring @50 wrap and won, BUT, only turned 8070 rpms, it pulled hard from start to finish, we ended up with 96.41mph with 23/39 gearing, it felt like it ran out of gear about 800ft out, might try 23/37 or 38 or 24/ 39 if I can find gears, we raced against a 25-30 mph head wind at 20 below wind chill, COLD COLD COLD, I kept telling myself I'm having fun. RJ21
The 89a10 are very good. With some tinkeing youll find very good mph with those. What other helix angles do you have to choose from??
you may want to try a set of 8bu-00 with empty pivot hole,2.4 rivet in the tip, (45/136kg)G/W/G primary spring and 48/40 rear helix with green dot sec spring at 50-60 twist, 23/37 gearing. track tight. walk it out softly before putting the coals to it...
Dont have 8bu weightsi have 8ca weights almost same profile tried them not good.
Helixs
52/44
47/39
48/38
47/41
8bv50 no idea what that is
also i had to replace 17 studs only on left side weird huh!
Helixs
52/44
47/39
48/38
47/41
fastsrx
Have you tried a green spring. If your running a pink spring that is real stiff for radar runs. I'd tried my bu"s this weekend, my weights are 49. 8 grams with ywy & pulling 8200.
