brethren
This is my first post so excuse me if I make mistakes. I have recently rebuilt a 2003 Viper 700 triple. The reason for the rebuild was a spun crank (PTO cylinder). Ever since the rebuild I can't get the PTO side cylinder to fire. It's running on 2 cylinders and about every 5 seconds the PTO cylinder wakes up with one fire. Rebuild includes the following:
Compression test looks to be normal at 1: 90psi, 2: 100psi, 3: 100psi (Compression tester not the greatest so values may be off)
Spark seems to be present when the plug is laid on the head
Plugs on cylinders 2 and 3 are nice cream colour, but the PTO cylinder is black.
I have tried to spray fuel into the carb while its running but it doesn't bring it to life, so I don't think its fuel related.
I've checked the reed valves which look good
Ive checked the primary coil resistance tested okay .5 ohms
Ive checked the secondary coil resistance tested okay at 5k ohms and the cap at another 5k ohms for a total of about 10 k ohms
In all my years of working on motors, I've never been stumped like this before. Any ideas? Might be parting it out soon, but I love this sled, it's mint.
- Specked Crank
- Rebuilt PTO cylinder
- 3 New OEM pistons and rings
- New piston pin bearings
- New head gasket
- Cleaned carbs (including low speed jets with thin strands of wire)
- New main jet nylon cups
- New NGK sparkplug caps
