Hi!
Thank you for a really good forum
I have a piped viper with some issues..
The backshift has become worse and worse. At first I noticed a little poor backshift, but I didn't ride as much deep snow then as I do now.
I have changed all the bushings and cleaned the clutches, no improvement.
Now I have the secondary winded up all the way (9-3 120 deg, I measaured tourque approx 20Nm) and it's better but not good, when I need the backshift the most - in deep snow, it's not there.
The upshift has always been good until now when I started to stiffen the secondary. If I push the throttle rapidly and don't keep an eye on the tach it over-revs until the shift-out appears.
So now I have two problems, but smaller.
Engagement rpm approx 4500, top rpm 9000, ok for me.
The sled has a heel clicker kit in the primary, red spring, bolts in the shoulder, nothing in the middle or tip. Green spring in the secondary (black spring, green markings), 42-36 helix. Track with 2" lugs, 8t sprockets.
Now it feels like I need a stiffer secondary spring for better backshift and more weights for the lack of upshift?!
I want it to work best in the deep snow. I tried a similar machine with stock pipe/silencer, - Up on viper sound and it just floated on the snow, worked great.
Can you advise me what to buy/do/change?
Robert, Sweden
Robert, Sweden
