travisgross4599
I have been working on a friends srx 600. The center cylinder blew cause the power valve cable broke. we installed new: rings to to cylinders 1 and 3. new piston and rings to cylinder 2, new jug to cylinder 2, new power valve and cable cylinder 2,and total new gasket set to top end,and cleaned carbs (weren't t bad). We started it and it is only running on cylinder 1 and 3. cylinder two seem dead it is getting gas cause it starts to drip out of the header. We checked the compression and it is 120psi. I thought the coil might be bad but the new plug has great spark. we put plugs from running cylinders in it and still nothing. This really has me baffled cause it should fire with fuel, compression,and spark. Could the base be flooded? Any help would be greatly appreciated
