denn69
Anyone here have any first hand experience with a 1993 and up phazer 2 crankshaft. I made the HUGE mistake of bringing it to the dealer to replace the main bearings. 420 dollars later I picked up the crankshaft. I didn't notice it before but the thrust washers are different from the mag side to PTO side. The mag side uses the 2 thin washers. The pto side uses 1 thin and 1 thick thrust washer. I checked the parts fiche and they are different part numbers along with the PTO(Clutch) outermost counterweight. I think the change was in 1993. My question is, the Mag side the connecting rod side clearance it nice and tight and the PTO side is loose as hell. The dealer said it is fine however I am way skeptical of two different clearances on a twin crank. The side with more clearance is not the side that was split. The crank fits back in the case perfect so I am not thinking that it was pressed to tight on the mag side. The trust washers look ok. Is it possible that Yamaha had more clearance from the factory on the PTO side? None of the rods bearings were replaced as I was told they are good. Any info on this mess will really be appreciated. Maybe some one has a phazer 2 crank lying around and can take a look. Thanks again, Dennis
