that machine typically didnt have problems with the temp sensor wiring, but dont rule it out. however, a solenoid failure code is is very similar to the temp code.
the temp code and startup flash will be around .5 second intervals. a solenoid flash is at .75 sec intervals. unfortunately there is no distinguishing between the right or left solenoid as the cdi just detects a solenoid issue. if in fact this is the code its tossing, its telling you theres an open circuit or short circuit with or to the solenoids.
back 20 years ago when that system was thought of as the latest and greatest, solenoid failure was a rarity. given the time and age, who knows what you have. what i do on the not so smart system is confirm that all the connections are clean. not knowing exactly where your at, i have seen some amazing corrosion on units east of the rockies. we dont see that crap on the left side of the mountains.
i would suggest confirming the code and yes, its hard to distinguish between the two. if your dead set on the sending unit for the temp gauge is proper, look to the wiring at the solenoids. before buying any parts, clean the tabs on the connectors and give her a run. from there, look at the connections for the cdi as well as a clean flywheel. you really should get the proper manual for your sled, your gonna need it. there are a multitude of diagnostic test to perform with an electrical tester for that system. cheapest place is right here on this site as snomofo mentioned.
