Sxviperrules99
Will this setup clear the tunnel with 8 tooth drivers? Or is there anything else I have to do?
Thanks,
Jake
Thanks,
Jake
yammitrip1
yes it will clear fine
devinzz1
^^^x2
Batwolf
Sweet, I'm looking to do the same thing to an '03 Viper that's been fitted with a 136" Attak skid. Does the above remain true with tunnel & front heat exchanger protectors in place?
devinzz1
Might rub a bit. Notch track where exchangers run. Some people just let the track wear itself in. Why not remove the protectors?
becuse the front heat exchanger protectors are welded in on a viper!
Yamaouch08
they're not welded real good tho,i put a screwdriver in the tube and swatted it and they can right off lol but maybe i was just lucky!
yammitrip1
you can take a hacksaw or even a little die grinder and zip them things right off in the middle of a track swap. Can even use a chisel as well.
devinzz1
Yessir. Probably wouldnt use the chisle though.
Sxviperrules99
Ya I'll remove them. Will it fit with the protectors?? Or must you take them off?
