traction question
srxguy
Glenville New York
ok...02 srx with 192 picks and chiesels..My question is, on Ice when I come out of the hole it hooks good for about 15 ft or so then looses traction and falls on its face then it hooks up again. I know front end must be going to high causing the track to lift off the ice. My suspension is all stock except for transfer rods that I have adjusted for full transfer...Is there any way to keep the front end down?...Should I Mess with the transfer rods?...What do you guys think?...Thanks for all the help!...Also one more thing, It seem it wants to go to the right on the way down the track...anyway to fix that also?...thanks again!.............. :rocks:
i have an 01 srx 700 and it pulls hard to the right, i have 192 studs also. i tightened up my limiter straps a lil bit to help with the front end coming up
If Your Only Racing Pull The Front Straps As Tight As They Will Go.you May Have To Put New Holes In Them To Get Tight. Make Sure They Are Equal Length On Both Sides, That Should Take Care Of The Pull To The Right.
