unplug the headlight bulb, remove rear tail light bulb and disconnect the handwarmer wires see if it will run better, this will give you all the available power from stator to the engine.
brianbailey440
also tried ignition switch,voltage regulator,rectifier,unhooked hand and thumb warmers,tried a ground from engine to chassis.tried everything!!! going after the stator tomorrow.
brianbailey440
thanks mr viper, but that wasnt it, changing the stator tomorrow
brianbailey440
changed the stator, sled revs now.going to try it today
brianbailey440
sled rips, problem solved !!!
