lil3incher
I was wondering if coolant runs through the fins on the exchangers? I have some fins damaged, also im adding an SRX rear heat exchanger to my VMax, what would be the advantages, I noticed its alot bigger
No. The fins just add surface area (making it "bigger"). If it isn't leaking, just keep an eye on it.
I haven't read that the SX is porne to needing a rear cooler like the SXV does.
sloTJ
I just had to replace my clutch side one because it was leaking at a crack in te usual place by the rear skid mount
