L lil3incher Member Joined Feb 2, 2014 Messages 97 Location Rushoon, Newfoundland and Labrador, Canada Feb 28, 2015 #1 I was wondering if coolant runs through the fins on the exchangers? I have some fins damaged, also im adding an SRX rear heat exchanger to my VMax, what would be the advantages, I noticed its alot bigger
S snomofo VIP Lifetime Member Joined Oct 31, 2006 Messages 2,133 Location Anchor Bay, Michigan Feb 28, 2015 #2 No. The fins just add surface area (making it "bigger"). If it isn't leaking, just keep an eye on it. I haven't read that the SX is porne to needing a rear cooler like the SXV does.
sloTJ Member Joined Jun 27, 2013 Messages 288 Location Cambridge, WI Feb 28, 2015 #3 I just had to replace my clutch side one because it was leaking at a crack in te usual place by the rear skid mount
