teamhystyk
It is in the wire loom next to grip warmer wires, it is a white with black stripe wire and blue with white stripe wire with a black connector with nothing attached to it? Im thinking its for the thumb warmer switch which I don't have on the sled? Am i correct? it was an engine swap into an older 1999 sled from a 2001, I am getting the code no continuity to thumb warmer, can I tie this in to the hand warmers? any help is greatly appreciated thanks
It looks like the thumb warmer switch... check it for voltage with a multimeter.
teamhystyk
Could I just splice this into to grip warmers? Instead of buying another switch
that would not help anything.... you could get a flip switch for on and off.
Yamakan
did ya figure it out? I may be able to help. Looked for ya last weekend...
