Backwoods M Max
So I had my first "fouled" plug experience. I think that 1 of my 3 plugs was bad from the start this season. I threw in a new set of BR9ES's and when I checked them the mag and center were perfect and the pto was black. The other day the pto cylinder dropped while out clutch testing. Eased home, pulled the plug and figured ok it's just because the pto is jetted rich. Cleaned the plug with a wire brush and brake cleaner to try it again. It fired for a little while then quit again. Came home and pulled it out and it was still clean but wet with fuel. I panicked, pulled compression just to be sure, 130 hot across the board.
Threw in a new plug, went out and ran it again and now it's dry with a nice smoke ring and great burn on the ground strap. Oh and the power is back, I think I was doing some clutch tuning with a weak cylinder but that's another story.
Please share your try's and fails with spark plugs and if your running alternatives to the oem recommended plugs? I saw something about Bosch plugs being very high quality and very consistent plug to plug.
