tippmannator
I posted this thread on the 4stroke side of an ice scratcher mod I did to my nytro, but thought everyone here could benefit from it also.... check it out
http://www.ty4stroke.com/index.php?threads/135318/
jdub-viper 700
thats pretty cool and look pretty good too, i think i might try this for my viper. great DIY!
Great idea.
tippmannator
Im kinda nervous about drilling an all plastic ski... but seemed pretty rugged so we will see how it holds up....costed about $10.00 total
I think some kind of collar over the bolt on the inside of ski would prevent the ski just pinching together when tightening the bolt would help. Or is there 1 there? Like a piece of 3/8" pipe or tube or something. Why does the hole need to be tapped and not just a 3/8 hole? Do those things really help all that much on glare ice?
rx1jim
Very nice work!!! Excellent idea and implementation. I have been wanting to do this for years, the scratchers definitely help on extreme hard-pack trails.
tippmannator
from everything I have seen and read, scratchers help preserve hyfax and aid the cooling process on icy days. I thought about a spacer on the bolt between the side walls of the ski, but when I bolted it down, the ski didn't even flex. I initially thought the ski was a hollow core and that's why I was worried, but when I drilled the hole its solid all the way through. the bushing is not tapped, may have used the wrong verbiage on the post sorry. just a hole big enough to fit the 5/16 bolt through.
I see. Might try that.
tippmannator
**********UPDATE************
pro:
was out riding just the other day with these scratchers and when I had them down, they seemed to help with cooling....trail conditions were somewhat icy spring trails...temps were low 30s. so they seem effective...
con:
storage location is finicky....the left scratcher kept popping out of storage on its own. further more, when attempting to store the scratcher, it snapped right at the spring. I think the issue is that when storing, im pulling at an angle that the sping is not ment to go (right to left) causing material fatigue.
pro:
con:
