80_srx440
Just picked up a 80 srx. Runs and drives but needs tuning . It has 36 or 38mm round slides on it . What would everyone reccomend for a starting point with jetting? Has 270 mains in it now . Not sure of pilots , slides or needles. I want to ditch the carbs on it for a better set of 38s . Previous owner had a problem wkth it blowing up because had a 76 head on one cylinder . I'm just looking for a good setup for the occasional drag race and trail ride . It also has a p85 on it with stock secondary so I'll be looking to replace that with a 102c. What belt will fit best with 102c and stock secondary? . I'd also like to pick up another set of cylinders for it. Thanks I'll get more info if need be.
			80_srx440
RICKYAMAHA
I may have a few good 8G9 cyls. for you and may trade for your 76 head . Please let me know the cast number on the head.. Is it 8A7 ??
			80_srx440
YAMMIEGOD3:16
thats a 76 head. pretty easy to see by combustion area and the fact it was milled. run a dayco max 1049 belt with a comet 102 c. 3:16 (yammie tony)
			80_srx440
80_srx440
RICKYAMAHA
could switch your 76 head for one 8J0 or 8G9 head. Let me know what you think.
			80_srx440
I've got 5 heads just looking for cylinders now I bought a whole complete spare motor. Id like to put this one back together eventually
			RICKYAMAHA
Let me know if you want to sell  the 8A7 head.
			80_srx440
Ya I'll sell it I sent you a private message rickyamaha
			cycle salvage
We still have lots of srx stuff left info@peterborocyclesalvage.com
			cycle salvage
We have SRX motor parts give me your lists on my parts search info@peterborocyclesalvage.com
			Yamaha Nutz
yes the crank should have the thrust washers on each side of the rods make sure to have the crank deflection checked  that cylinder can be repaired to like new condition by US Chrome ..............
			unchained
Why the 1049 belt Tony? 1106 is standard correct?
			YAMMIEGOD3:16
1049 was wider, same length as 1106. 3:16x (yammie tony)
