Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 24
Thread: SXVenom Build - Running Log
  1. #11
    Default
    Good to hear the bearings in that center shock work well . Do you mean new bushings in the lower W arm mounts, or is there a way to get bearings in there too?
  2. #12
    Senior Member Open Mod roudyroy1's Avatar
    Join Date
    Jan 2013
    ontario GTA
    Posts
    1,473
    Default
    yes bushings, i almost guarantee that they have turned to dust. drill and tap grease fitting into the lower mounts. it will make them last alot longer, then replace with new bushings and shim them if necessary
    a wise man from canada once told me
    "there are only 2 types of sleds. 2 STROKES and 4 JOKES" !!!
  3. #13
    Default
    Well I didn't work on this nearly as much as I wanted this year. I should be getting the rebuilt shocks back from Hygear tomorrow. I also bought a 3" block riser to get the height back when I put the MX bars on. Should end up around 1/2" taller than stock bars. Powermadd suggests cutting the nub off of the stock lower bar clamp so it sits flush on the riser, think I'm just going to put the riser on the drill press and drill a hole down for the bar clamp to sit into instead. I'd rather keep the stock components unmodified.
  4. #14
    Super Moderator super1c's Avatar
    Join Date
    Sep 2003
    Freeland & Otsego lake, MI
    Posts
    5,047
    Default
    I cut that nub off all my sled with risers. Not needed and never was a problem.
    2002 Yamaha SXViper - Daughters
    E-start, reverse, extended to 144" with cobra track. Awesome EdgeWrap in purple and pink!!
    2016 Yamaha SRViper LTX-SE - Wifes.
    2017 Yamaha SRViper LTX-LE - Mine
    THE VIPER PIT IS NEVER COMPLETE! Bipolar!!!
  5. #15
    Default
    Trying to put the Pro Taper 7/8"-1 1/8" adapters on my sled with a 3" block riser from Powermadd. I cannot find the correct length (115mm) button head socket cap screws to make this possible... Regular socket cap screws will not work as the head is too large and the bars will not sit flush in the adapter. The button heads can only work, but I can not find any in 115mm length. Anyone know of any vendor?
  6. #16
    Default
    Here's some photos if it helps. You can see the setup I'm trying to do, it'll be the stock stem/steering post, to the 3" riser, to the stock lower clamp, adapter, bars, then upper clamp to adapter. First photo shows a 110mm regular socket cap screw (too short, need 115mm) for length, second shows why the same one will not work (will hit bar), and last shows the difference in what I need (left) vs. the same previous bolt.
    I really didn't think it would be this find to find some bolts, I can't be the first person to do this...
  7. #17
    Default
    Found some in 120mm, but I'm not paying $190 for 100 bolts when I need 4. http://products.coburnmyers.com/item.../8c120kbc-12-9
  8. #18
    Senior Member Open Mod A couple of bucks's Avatar
    Join Date
    Jan 2009
    Ogle County Illinois USA
    Posts
    5,854
    Default
    $1.86/pcs
    https://www.fastenal.com/products?r=~%7Ccategoryl1:%22600000%20Fasteners%22 %7C~%20~%7Ccategoryl2:%22600039%20Sockets%22%7C~%2 0~%7Ccategoryl3:%22600040%20Socket%20Cap%20Screws% 22%7C~%20~%7Csattr01:%5EMetric$%7C~%20~%7Csattr05: %5E120mm$%7C~&resultsPerPage=48
    Dannyboy
  9. #19
    Default
    Thanks bucks. I ended up putting a 7/8" bar on it instead and didn't bother with the whole adapter. It's a Pro Taper bar RM bend. Put OEM grips on it but needed an extension between both sides. My dad used to work in shops and happened to have the right connections, I believe what is used here was from a 70's bike. Also put some Cycra hand guards on it, needed to bend the brackets so they wouldn't hit the windshield so easy. Still rub it a little but are in a good position I think. Fired it up tonight and sounds good, just currently dealing with a TORS issue: https://totallyamaha.net/showthread....ent-TORS-Mount
    20180120_180627.jpg20180120_185322.jpg20180120_190344.jpg20180120_190401.jpg20180120_191100.jpg20180120_191109.jpg20180120_191122.jpg20180120_191134.jpg
  10. #20
    Default
    Did some local riding this weekend with a friend. Within the last mile back to the trucks today I hit something buried in the snow that I didn't see hard enough to bend my right trailing arm. Wasn't going very fast, maybe 20 or so, hit hard enough to rip the bars out of my hands... Was hoping Kimpex made a replacement but looks like they only make them for the short spindle sleds...
    Nothing seems to be binding, I can still wiggle the tie rod around even. I'll keep it on for the rest of the year then see what I want to do. OEM pricing is about $350...
    Edit: Found this, never heard of Extreme Sport Parts, but it looks pretty damn close to OEM. Might be worth trying it out. https://www.ebay.com/itm/Yamaha-Snow...5UxyQl&vxp=mtr
Posting Permissions
  • You may not post replies
  • You may not edit your posts
