Page 7 of 7 FirstFirst ... 567
Results 61 to 70 of 70
Thread: Years with Yamaha SXViper
  1. #61
    Default
    Bulkhead is okay, if front shocks bottom that causes bulkhead cracks. Most biggest problem is front cooler and sump shield rivets. All rivets are loosen or off. I think i'm going to replace them with long 6.4mm steel rivets and add some aluminium profile.
    But today i finally get engine running, that feeling was awesome
    One exhaust flange is leaking a little, but i think that i'm going to put some heat silicon, i don't want to cut and weld those pipes anymore. It was pretty annoying job to get everything fit and build those silencers.
    Next step is build exhaust gas temperature meter and paint some YAMAHA logo to seat, like original seat. And also i need to find some motivation to create a code for arduino, i already have a 4-channel egt-k "amplifier" and all connectors ready!
    I think that it would be most easiest way buy some, but i wan't to make everything by myself.
    Yamaha SXViper 2002
    2" riser
    44" stance
    Blue headlight cover
    DIY windshield
    18.9" fox floats on front end and 18.7" fox float on rear skid
    Tunnel stiffeners and protective tube
  2. #62
    Default
    Little update, i bought another viper! Or actually i change those speedwerx pipes to viper frame. I thought that i put 780 on frame that i bought and then i fix my modded yamaha`s frame. I think that i put stock 700 with bender 4x4 pipe and finally build rack steering on it. What do you think?
    As you can see on the pic that swaybar is assembled wrong... But that is now fixed, windshield is is cutted to low and i make my own style cold air intake also
    Yamaha SXViper 2002
    2" riser
    44" stance
    DIY windshield
  3. #63
    Senior Member Open Mod A couple of bucks's Avatar
    Join Date
    Jan 2009
    Ogle County Illinois USA
    Posts
    6,326
    Default
    Whenever you get those 2-speed HeelClickers, insure that the pivot pin update has been done. Or needs to be done. I remember someone saying something about that. I think in another of your threads. I don't want it to fail and wipe out your clutch.
    Dannyboy
  4. #64
    Default
    Quote Originally Posted by A couple of bucks View Post
    Thanks for info, i need to check it! And also thanks for those heel clicker weights
    Yamaha SXViper 2002
    2" riser
    44" stance
    DIY windshield
  5. #65
    Default
    Finally it's getting cold and some snow. Other sled fixed and almost ready to ride
    325x38x44 track and relocated chassis. Fixed skis on front and some fox float reservoirs on front.
    Now engine is stock 700 with bender 4x4 pipe and stock mufler.
    Made some new brackets for chassis and changed many rivets on frame, i used wyrth 6.4mm steel-steel rivets.
    And some pics ofc
    Next step is ride and build that other viper for lake rides.
    Yamaha SXViper 2002
    2" riser
    44" stance
    DIY windshield
  6. #66
    Junior Member Mini
    Join Date
    Sep 2019
    Labrador Canada
    Posts
    3
    Default
    Nice build! Do you have any pics of how you mounted those fox floats to the bulkhead?
    2003 Yamaha Viper Mtn. Bender pipes and clutch kit
    2003 Yamaha Viper Mtn. Mbrp race can beater/water sled
    1999 Yamaha Waverunner 1200Gp. Riva racing intake
    1986 Yamaha 200 Tri Moto trike
  7. #67
    Default
    Quote Originally Posted by Jordan9252 View Post
    Here is some better picture
    Yamaha SXViper 2002
    2" riser
    44" stance
    DIY windshield
  8. #68
    Join Date
    Jan 2009
    Posts
    6,326
    Default
    Quote Originally Posted by sx viper View Post
    One exhaust flange is leaking a little, but i think that i'm going to put some heat silicon.
    If it's the donut you're talking about ..... I have cut up long strips of steel wool from a batt. Then I wrapped it around the donut. Finished it up by working RTV into the wool. Install it wet on clean surfaces and it will adhere.
    Dannyboy
  9. #69
    Default
    Hi,
    Finally started to do something special. Many hours of fabrication and designing. But now it is fitted! I'll post some more pics when it is ready and also some story of my riding trip when chassis rear brackets broke down...
    Bumb steering problem is now solved, next weekend going to test how it works. That steering problem was pretty bad cause i used those long fox float and "stock" steering.
    Yamaha SXViper 2002
    2" riser
    44" stance
    DIY windshield
  10. #70
    Default
    Quick pictute update, rak steering is awsome. It works nice�� Been riding and some little fixing also, shock mounts need to fix and chassic bolts need to replace, but it was possible to do on "field"IMG_20200316_125042_copy_648x1152.jpg
    Yamaha SXViper 2002
    2" riser
    44" stance
    DIY windshield
Posting Permissions
  • You may not post replies
  • You may not edit your posts
