Page 8 of 8 FirstFirst ... 678
Results 71 to 76 of 76
Thread: Years with Yamaha SXViper
  1. #71
    Default
    Some riding pics with stock 700, everything works good. I was also riding with 780. It runs pretty good, but got some airleak somewhere. Need to check it later.
    Yamaha SXViper 2002
    2" riser
    44" stance
    Blue headlight cover
    DIY windshield
    18.9" fox floats on front end and 18.7" fox float on rear skid
    Tunnel stiffeners and protective tube
  2. #72
    Default
    Awesome! The steering rack looks pretty cool, does the steering 'feel' the same with it (turn bars a certain amount and skis still turn the same amount as before)? Is that a motocross track in the photos?
  3. #73
    Default
    Quote Originally Posted by Yzed608 View Post
    Steering feels almost same, skis won't turn as much as before mod. It is possible to modify those links and get it little faster and more angle, but i think that it is not nessessary. Stock viper skis turn a lot compared to other sleds. It is also a little lighter to turn compared to stock. I run pretty much ski pressure so it is possible to ride fast on bumby turns. I have some videos, but i need to make some edit on clips.
    Actually that place is a local small skiing hill, they made some bumbs with machines�� It is closed pretty early, because covid...
    Yamaha SXViper 2002
    2" riser
    44" stance
    DIY windshield
  4. #74
    Junior Member Mini
    Join Date
    Jan 2020
    San Jose, CA
    Posts
    17
    Default
    Nice photos. Were you able to solve your issue about the airleak?
  5. #75
    Senior Member Open Mod A couple of bucks's Avatar
    Join Date
    Jan 2009
    Ogle County Illinois USA
    Posts
    6,347
    Default
    I am not for sure on this, I believe the length of a tie rod or something w/ the steering parts are different lengths when comparing a standard travel(SX) to an extended travel(XTC?) front end.
    Again ..... I'm not positive on this.
    Just some food for thought.
    Dannyboy
  6. #76
    Join Date
    Jan 2009
    Posts
    6,347
    Default
    Quote Originally Posted by sx viper View Post
    I think Hauck just call them Venom heads.
    Attachment 64880
    I take it that there is a CC difference in the domes? Or shaped differently as opposed to stock heads?
    Dannyboy
Posting Permissions
  • You may not post replies
  • You may not edit your posts
