Results 1 to 7 of 7
Thread: Just sayin thank you
  1. #1
    Junior Member Mini
    Join Date
    Sep 2019
    Minnesota
    Posts
    17
    1 out of 1 members found this post helpful.
    Default Just sayin thank you
    Bought a 98 xtc deluxe late last season for rookies, guests, etc. Knew the original owner and was nearly perfect. Looked for info on maintenance, dependability mods etc. Ended up back here most of the time on google so thought i may as well sign up.
    Did the required bearings etc and thought as long as im here may as well keep going so I replaced the rear skid with a ski doo sc5 I had laying around. It had been gone through and was just sitting in the corner. Also I consider the stock skid an abortion. Sorry. Put on a 1.25 new track and will now be looking at a reed notch and some clutch improvements. I will be putting on some pilot 5.9 skis I have laying around as well.
    Picked the redhead well because it's a redhead and a perfect teaching tool. So thanks for all the info on here.
  2. #2
    Default
    Now throw on some triple pipes and embarrass most other sleds.
    1997 Yamaha XTC
    700 Redhead, Mr. Viper ported, CPR pipes, SRX reeds, Heelclickers, Dual bulb, LT Ohlins
    1997 700 SX
    Thinned head gasket, Gutted Airbox, Reed Spacers, Bender Pipes, Viper Shocks, 51/43 helix 89L weights
    2004 Viper S
    SLP pipes, peak performance head,
    2001 SRX 700
    Power Inc. Pipes, Loaded 8DN20's, Hauck Y 51/45
    1997 Mountain Max 700
    Black XTC Hood, Thinned Head Gasket, Gutted Air Box, Reed Stopper Notch, SLP Pipes
  3. #3
    Senior Member Mod Vincent's Avatar
    Join Date
    Aug 2015
    Ontario Canada
    Posts
    997
    Default
    Nice! Witch redhead? 600 or 700
  4. #4
    Junior Member Mini
    Join Date
    Sep 2019
    Minnesota
    Posts
    17
    Default
    Murder, no for 2 reasons
    1. It's for rookies I need a sled that will be dependable, gentle, and will run forever. To quote me "If you want to go faster buy your own damn sled"
    2 I sure as hell don't need anyone beating me on my etec 800 ski doo THATS what would be embarrassing
    Vincent. The only true redhead the 700
    I may do the head gasket mod but it's not a pooch as it is and Oooooooo that sc10 rides damn near as good as an rmotion. Oh yeah should rebuild the shocks in front.
  5. #5
    Senior Member Open Mod A couple of bucks's Avatar
    Join Date
    Jan 2009
    Ogle County Illinois USA
    Posts
    6,308
    Default
    1. Only one layer should ever be removed from the three layer head gasket. Just drill out the (2?)rivets holding them together. A light dusting of Permatex spray Copper Coat on warm gaskets will give you peace of mind for a leak free mod.
    https://www.farmandfleet.com/product...iABEgJJdfD_BwE
    https://totallyamaha.net/showthread....ght=Wood+stove
    2. CarbonTech reeds and notch is a one-two punch. Smooth and easy starting.
    https://totallyamaha.net/showthread....ight=Stainless
    https://totallyamaha.net/showthread....ght=Carbontech
    3. Plug caps
    https://totallyamaha.net/showthread....hlight=TB05EMA
    Dannyboy
  6. #6
    Join Date
    Jan 2009
    Posts
    6,308
    Default
    What else is in your stable?
    Dannyboy
  7. #7
    Junior Member Mini
    Join Date
    Sep 2019
    Minnesota
    Posts
    17
    Default
    Carbontech that much better than stock?
    I assume we pull the metal out and glue gaskets together?
    2014 renegade x 800 11,000 miles. Never touched the motor. Thinking about trygstad since he's in my back yard but I check compression and crank run out every year along with anal retentive maintenance.
    2000 700 sks polaris built for deep snow
    1996 ski doo mxz 440. Blueprinted chassis and motor. This was our last racing sled. She still looks like we just took her off the track. Won WSSA took second in MRP in pro stock and stock classes of pro ice. Both extinct organizations now. Any old racers out there remember Wild Willy Jensen?
    73 340 fa ski doo
    71 ski doo nordik 399. My dad was the original owner
    That's all that's left. Lots of regrets on one's I should have kept oh well I can say that as well with cars and guns.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
