Phazer-I/II
WRP running board: http://www.wr-products.com/products/wrp-mountain-tuff-running-boards-yamaha-phazer-1985-1998
Anyone have experience with these or have pictures of them ?
sleddineinar
I've wondered the same thing.
			PZ 1
 - Mar 12, 2005
You will have to try them Lasse... and let US know what they are like
			TURBLUEI am putting a set of Polaris Pro boards on.
Fit pretty well with a bit of trimming.
 Please post a lot more pictures in high resolution and tell us more about your modification !
So basically I lined up the closest rivet hole on the front under the footwell.  One of the rivet holes lines up with the Polaris.  Then I removed the back bracket out of the boards and cut the middle slit longer to slide it in further.  Then cut the tip off the bracket and drilled a new mounting hole. Bolted the board to the foot well brace up through the bottom by drilling a hole.   Basically trace everything out and used a air saw to cut the boards off.  They actually fit pretty well and very ridged compared to stock. Never cost much these boards were off a damaged sled.  I can get specific pictures if you like, just getting them powder coated now.
Also installing a 141 1 3/4 track, custom seat, new tunnel ext and bumper, higher bars and moved forward , just more rider friendly in the mountains.
l
l
							I can get specific pictures if you like.
  Post a lot of full size high resolution pictures to my personal E-mail:   jecmel@hotmail.comThe more pictures, the better !!
krisdecker
Those look awesome!!!! i definitely want to add those!!
			Jean-Francois Aubin
Hi, what is the model of your pro boards? Do you have more high resolution pictures? It is possible to send your picture by emails?
spirudamax750
Turblue is that 136 and your changing it?  If so would you want to get rid of the 136 rail extensions?
			Jean-Francois Aubin
The more pictures, the better !!![]()
Hi Lasse, Do you have received pictures from Turblue? Do you known waht is the model/make for the beautiful running board?
Regards.
J-F
Extreme Elmo
those are polaris pro rmk boards modified to fit
			Jean-Francois Aubin
Yup pro rmk boards and 141 track. Fit pretty well. Need to bolt seat down and should be good to go.
Very, very nice. How it cost this polaris pro boards?
Please post more high resolution picture. I would install also.
regards.
J-F
spirudamax750
When changing the length of the skid do you have to change where the suspension bolts ? I'm going to make my phazer 136. Do I have to move anything or is it a bolt up and go? I know i need to make my tunnel extension
http://minneapolis.craigslist.org/csw/snw/5419482148.html
Here's a couple I thought about buying.
