The pic above is a good one. I did take some for you, it bolts to the tab that the pull start rope goes through. Now on the 98 it is routed behind chaincase but on my vipers that tab is used to route pull rope through. So yours will have it.
Awesome job on the pics. I ordered a new clamp, so I'll compare your pics to my sled tonight.
Think I found the issue. If you look at the guide for the pull rope (which is where the hose clamp should mount) you'll see it's broken off. No wonder I couldn't find the mounting hole!
super1c
Super Moderator
Ahh man. Only fix for that is new chain case cover. Any will work and should be able to find one cheap around here.
I think I'll just mod something that I can slip under that tight *** battery mount strap to lift the hose up a bit. I would normally be a bit concerned the rope may jump out of that slot now without it being secured by the hose clamp, but the good thing is I added electric start this year, so hopefully I won't be tugging on that too much anymore. Thanks for all the research.
One more question while I have your attention. The prior owner tie wrapped the battery cables to the coolant hose to get them out of the way. Does that hose get hot enough to do damage to the cables? If so I'll pull them away.
super1c
Super Moderator
No mine are there also. Never had a problem. Even my Maine wireharness runs right there also.
