staggs65
Head gasket
Triplethreat700
Ok gonna pull head off this weekend and scope thinks out. Thanks for the help
A couple of bucks
HighlanderThere can only be one.
staggs65
If you pull the head off make sure you drain the coolant down first. Otherwise you'll spill coolant into the engine and not know if there was actually any in there already
Triplethreat700
What's the best way to drain coolant?
drew24
There is a drain bolt on the water pump housing. It is right under the exhaust manifold in between the pto and center cylinder. It will have an extra washer on it compared to the other bolts on the housing.
super1c
Super Moderator
Another easy check if not mentioned yet is to look down into the piston dome through spark plug hole. A coolant leak will wash piston dome clean, it will look nice and shiny. A pic of that plug would clear things up in a hurry also. Pic's worth a thousand words!!
staggs65
Agreed. Pics will help alot. If you're going to put the opticool gasket then you have to pull the head either way. Pics of the pistons will help too
Triplethreat700
I know I thought about a pic after I blew off the spark plug. I looked down the hole and top of piston had normal carbon build up. Maybe this just happened because I started it for the first time in 2 years or so of sitting before I bought it.
A couple of bucks
Even the smallest, seemingly insignificant flaw in the head gasket is magnified significantly at 120 psi. Or whatever your leakdown tester reads.
Triplethreat700
I'm thinking of going over to harbor freight and see if they have a leak down tester that will work for me. Been wanting one and now would be a good time.
staggs65
Probably just condensation from sitting so long
Triplethreat700
Could be just was a little worried cause bottle was empty.
A couple of bucks
If you do get a h/f tester, make sure the gauge can get to 0(zero).I'm thinking of going over to harbor freight and see if they have a leak down tester that will work for me. Been wanting one and now would be a good time.
Triplethreat700
Ok will do thanks guys for all the helpful responses. The more I think about it the more I'm thinking It was condensation from sitting that staggs mentioned. Never thought of that.
