Labrador-Ronin
Hello all, I am just posting a video to see if anyone has any ideas, I have checked the harness, its ok, as i can see, and the harness on the hood, has some fraying, im going to strip and check, also recheck the whole harness, then re wrap it, she was warming up for 10 minutes beforehand, it was plus 3C here and had a bit of raining, i need to get her into the shed again i knows, the soother someone mentioned, and the CDI box, where is that located, I looked in a schematic, couldnt find it, also checked google, just gave me shops with them in stock...
She seems to be runnign on 2 cylinders, all but the PTO side, its strange, they are all new plugs
Any advice would be great, sorry for the bad video, I am not proficient in any capture of anything, hunting another matter LOL
Smoothing condensers is that round looking abject on the harness attached to the underside of the hood. The CDI is under the right side foot hold.
http://www.portyamaha.com/fiche_sec...Snowmobiles&make=Yamaha&year=2002&fveh=176276
Labrador-Ronin
Ok thank you sir, I'll have to get the cab panels and seat off
Labrador-Ronin
I forgot to ask what resistance should each part have when I check, I couldn't find anything at all
It would be better to just become a VIP then I can send you the link to the manual, should help keep the questions downI forgot to ask what resistance should each part have when I check, I couldn't find anything at all
Labrador-Ronin
HAHA true but alas I need to find the cash and get a credit card. Seeing I don't use PayPal
Sent from my D5106 using Tapatalk
Labrador-Ronin
I checked the VIN shes a 2002.... registration said 03 HAHA,
did you check for spark on the cylinder that is not firing. they make a tool that you can use and see the spark. Might be a bad coil? Did you clean the carbs?
Youllbe2nd
I'd say that because your gauges are out that you've got a rub through somewhere. Possibly under your motor. There's wires that run down beside your pull cord that can come out of their home so to speak and the pull cord can rub through them. Something to check. I lost my gauges once because the cable in the hood came loose and rubbed through on my pipes. I think your on the right track. Also make sure to clean the fly wheel of any rust, check plugs, plug wires and all wires for rub through as these are all common issues.
Sent from my E6560C using Tapatalk
Labrador-Ronin
I checked, the spark, she sparks on all coils, the carbs had a quick clean, next time I take them off I'm going to change the fuel lines also, a precaution, should I go with the cheap vinyl or the black rubber? Thought I'd ask.
I'm going to try take the exhaust off and the recoil to check everything, I need a flywheel puller and clutch puller for the sled tho, I checked the hood harness, it had a few places, well alot taped, most of the length was taped but still was soaked and I'm letting it dry and then checking it over once more before I re tape and it's lithium grease correct? dad uses Vaseline haha
Youllbe2nd
Vaseline or dielectric grease. However Neither are a conductor.
Labrador-Ronin
Yah I figured, it's a white lithium grease they use eh? I can't remember, I'm automotive we used di electric
Labrador-Ronin
I set her out in the cold, the center cylinder was dead, spark plug was good, the cap arced between the connection and the wire, had to snip a bit had a few wires that made the connection, runs better, but going to pull the harness to check and the relays, and check the resistance
Labrador-Ronin
Ok gang, she runs better, ni rubs in the harness, only problem the gauge pod, no nights, tack doesn't move, no warning lights, and head lights are dim, no change between the high and low beams, I'm guessing the relay, if not I'm at a loss. Going to replace it now
yamahamark
Gauges still out is smoothing condenser
Labrador-Ronin
Ok I have two on mine, crap what's the resistance they supposed to have? Any idea?
Labrador-Ronin
Ok I unplugged the headlights, and the gauge works same as the tach, the grips and thumb warmers were off, I'm confused, what it could be, could it be the stator or the condensers, I'm tried everything possible besides pull the stator, hope it's not that
Can u try another cdi?
Labrador-Ronin
I'd have to buy one lol, I'll have to add it to my cart and see the cost,
I might have a used one I could sell u.
