What are guys using on the outer edge on a viper for grip? I'm thinking sheet metal screws.
I used the rox edge grippers. http://roxspeedfx.com/collections/s...e-grippers-traction-strips?variant=1197849841
If I remember correctly, Rox will even build you a set of Rox treads. About $250 iirc.
They are awesome. I looked for a set for a long time after riding my dads sled with them. Ended up making a set. I'd prob pay 250 for new pair though.(if I needed them) I just worked at a small fab shop and got the material for free, figured why not take a stab at it. I'll see if I can find a pic when I added the edges.
I hav the rox treads was wondering about the edge I bought them used and the edge is smooth with a bunch of holes. so i bought these hope they work http://roxspeedfx.com/collections/s...p-strip-kit-10-per-package?variant=1178514941 do they normally come with something for that spot?
Backwoods M Max
I have sheet metal screws on the rolled edge of my mountain max and it works great. i spaced them about every 2". I picked up one of those value tubs at home depot. 1/4" heads with about 1/4" thread so they don't want to poke out the back side. put a strip of masking tape on the rolled lip so you have a straight edge to follow, mark the spacing then center punch so the screw doesn't wander when it's drilling. I buy the harbor freight spring loaded center punches by the handful. I keep one in every tool box and my drill bag, it makes the layout super easy.
super1c
Super Moderator
Those are the new version of the rox edge grips, those look way better. I did a version of BTV's running board mod on my wife's Sled. I took cat rails to make them wider then filled in the gap with diamond plate and riveted together. They are nice and wide with good grip. I'll see if I can get a pic up with my phone. Not good with this thing. Lol!
