Seems a little low shifting 5000 to 5500 rpms.
goes really good off idle then a big dead spot around 50-55K or where it quits pulling.
yamahamark
I'm having the same problem with my 97 sx 600 I even rebuilt both clutches and still have that problem.
Not ridden in 2 years
Sent from my SAMSUNG-SM-G920A using Tapatalk
Youllbe2nd
I wouldn't run 2 year old gas. Clean those carbs
Sent from my E6560C using Tapatalk
drew24
I had a vmax that acted like that. I put a different primary clutch on and it was good to go.
It was siphoned out with 5 gallons fresh added
carbs are gummed up for sure...clean them really good first and then see.
I know it's not the pilots or the mains. Lol
A couple of bucks
Bypass TORS and report back.
yamahamark
Ya know I didn't have this problem before I cleaned carbs and my carbs were full of belt dust p/o never cleaned them. But it run great no problems then I cleaned them and that's when my problem started.
It's hard to start now when cold about 8-9 pulls where before it would take 2-3 pulls cold.
Is it possible that I have something backwards or forgot something?
drew24
Might be able to clean the clutches. Seems like they get "sticky" when they sit. The secondary in the vmax is so stiff at the beginning of every season it is almost impossible to get the belt on. It does loosen up after the first good ride though.
Clutches r clean
YAMMIEGOD3:16
clean your carbs real good. go past needle and seats to screen and o-ring. 3:16x (yammie tony)
I did clean carbs all passages with carb cleaner.
It felt like a touch of bad gas, not wanting to make power. A lot of time was put into cleaning and tuning carbs.
drew24
Could the exhaust be partially plugged?
Drew,
Very possible. My cats chase and eat so many mice.
drew24
I need to get a cat. I have been going through poison like crazy and they are still all over. I had one come out of my exhaust when I fired mine up this year along with some of a nest.Drew,
A couple of bucks
Blip the choke at 5-5500 RPMs.
Couple bucks,
I just remembered it ran out of gas trying to drive it out the garage to be outside for the winter.
Coulda sucked somthin up pissibly,
