nick5oh
Having some issues with the sled and want to make sure I'm set right before installing my new belt. 99 srx stock clutching. Thanks guys
Yes springs def wear out, I would replace yours. Primary spring sacked out would cause under rpm condition, weak secondary will not back shift properly. Have you ever replaced anything on the clutches?
this is very critical on the performance of your srx, that sometimes gets over looked. exactly why the three small set screws with the washers are so important. that little bit of height for me on the asphalt. flush 114-115 mph. set to spec. 121 mph. 3:16x (yammie tony)
Good to know! Do you think 2.5 mm is ok? Like I stated above it may sink a bit once I rev it up high but not positive. Have only revved it up enough to engage it and get things turning.
Thanks for all the good info guys I appreciate it
Pickup the 3 bolts from your dealer #12 in this diagram yours are most likely wore on the tip.
http://www.cyclepartswarehouse.com/...Snowmobiles&make=Yamaha&year=1999&fveh=176229
set it to yamaha spec. thats what i did. 3;16x (yammie tony)
Belt height
Yes they are and there's two different thicknesses. Use the yammi ones.Those shins are yammy part numbers?
Did you not believe him????Can you confirm the spec?
