Duff man
Hey crew
New to Totally Yamaha here. .
I picked up a electric start kit off used parts dealer, however it didnt have the fuse box which I understand is a common issue with those adding electric start to their vipers.
I know there is a capped connector on the right side of the sled that has to be wired to the relay. .
Question, The capped connector has three wires, the relay is four prong. . Exactly what wires go where to make this work?
super1c
Super Moderator
http://www.totallyamaha.net/forums/...-Start-Install?highlight=Electric+start+relay. Will give ya where wires go. No fuse box needed. I'd I did it again I wouldn't even bother
Duff man
Thanks !! Works perfect now
bansheewyd
- Jan 21, 2025
Any idea what happened to this thread?http://www.totallyamaha.net/forums/...-Start-Install?highlight=Electric+start+relay. Will give ya where wires go. No fuse box needed. I'd I did it again I wouldn't even bother
Maim
Super Moderator
this should help you.
bansheewyd
- Jan 21, 2025
Hi and thanks for the link! I’ve read though that before, I’m just looking for some clarification on the Viper fuse block. What was the purpose of it? For accessories? It doesn’t seem required for electric start itself.
super1c
Super Moderator
No need for it. I made my own the first time just cause Yamaha had one there OEM. But the other half dozen I did I did not do it. Everything worked and still does work just fine without. Just over built like everything Yamaha did back in the day.Hi and thanks for the link! I’ve read though that before, I’m just looking for some clarification on the Viper fuse block. What was the purpose of it? For accessories? It doesn’t seem required for electric start itself.
bansheewyd
- Jan 21, 2025
Thanks you sir for the clarification. I’m after reading your posts and appreciate them a lot- very informative. I’m the type I love to keep everything “factory”, so not being able to track down a fuse block has thrown me for a loop!No need for it. I made my own the first time just cause Yamaha had one there OEM. But the other half dozen I did I did not do it. Everything worked and still does work just fine without. Just over built like everything Yamaha did back in the day.
Now to track down a factory connector for the lead between the relay and the ignition switch…
Thanks again,
Matthew
super1c
Super Moderator
I built my own back then. Side I couldn’t find one. Best best is to find a ER wire harness and switch them out or cut off and splice in if wanted. But wasn’t worth the time to me. Now the lead may be tough. Usually comes with kit but you must be piece meaning this together. It’s been a while but if ya need any help just hit me up. I still have most my nots laying around the garage.
super1c
Super Moderator
Yamaha SX Viper ER 700 Electric Start 2002 2003 Main Wiring Harness 23122205 | eBay
Find many great new & used options and get the best deals for Yamaha SX Viper ER 700 Electric Start 2002 2003 Main Wiring Harness 23122205 at the best online prices at eBay! Free shipping for many products!
www.ebay.com
Out of Canada but cheap enough. Everything ya need
bansheewyd
- Jan 21, 2025
Looks like the cap on the lead from the ignition is actually a connector. Now to find the proper pins! WoooYamaha SX Viper ER 700 Electric Start 2002 2003 Main Wiring Harness 23122205 | eBay
Find many great new & used options and get the best deals for Yamaha SX Viper ER 700 Electric Start 2002 2003 Main Wiring Harness 23122205 at the best online prices at eBay! Free shipping for many products!www.ebay.com
