BornYamaha
Yamahas are different than other brands. They actually use all that goofy stuff with weird shapes inside to tune the intake. Other brands there are many sleds that you could pull off and be fine with a little jetting but it really is a problem to do it on a Yamaha. Especially with the butterfly carbs that sled came with. We are just trying to keep you from getting less satisfied than you already are. There is a good chance of a lean meltdown or if you jet up enough to stop that it will most likely run like $hi+. I wish you the best.
Sent from my SM-G920V using Tapatalk
